Obtaining maximum speed
2005 Rinker 342 Fiesta Vee,  what are some causes for not reaching maximum speed when the throttles are fully engaged? Has the engines serviced, had barnacles removed, the hull cleaned and painted, outdrives are in good condition. Any suggestion are appreciated.
  • YYZRCYYZRC Member Posts: 5,498 ✭✭✭✭✭
    What’s your max RPM?
    If you are looking for more speed, most everyone on here will recommend the Hill Marine props, myself included. They give great stern lift.
  • aero3113aero3113 Member Posts: 9,959 ✭✭✭✭✭
    Bad fuel, incorrect prop pitch, worst case worn engine. Depending if the engines were fully serviced (plugs,wires,distributor cap/rotor,filters,flame arrestors cleaned, timing checked)
    Also, not trimming the drives and tabs correctly or something wrapped around the props.
    Or dirty bottom
    edited June 2021
    Or dirty bottom
    He already cleaned the bottom.
    At wide-open throttle, both engines should reach the same RPM.  If not, look for issues with the engine that has lower RPM.  Chafed spark plug wires, etc.
    And by maximum speed do you mean engine RPM or speed over water? I think the important question is are you getting max RPM's out of both engines.
