Weird Alarm
raybo3
Administrator Posts: 5,617 admin
OK here goes. I went for a shake down run and needed fuel. I was on my way into the Boston Harbha when I got an alarm. Very common for first trip. Usually I get the alarm because my S/B side drive "burps" and I have to fill the gear oil res. So I raise the hatch and the bottle is full. Keep in mind as soon as I went to idle the alarm stopped. So I powered up again and 15 minutes later alarm came back just as I was entering the Harbha. Lowered the RPM's and again it shut off. So I went no wake, filled the fuel tank and started for home. Once out of the Harbor I powered up (about 3900 rpm) all the way back and ran great with no alarms. Question, what the heII could cause the alarm then fix itself?
2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com
Even if the coolant temp looked okay, insufficient flow of raw water can produce a manifold hi-temp alarm at high RPMs.
