HHH on AC panel
I have a 2000 Rinker 310 Fiesta Vee and it just started to show HHH on the AC panel and the AC stops working, I googled it and says insufficient heat transfer to condenser, is there a strainer or filter of some sort that may be plugged up? It works great for about 3 minutes and no discharge from AC outlet? My boat was sitting on the dock and a raft of weeds and algae surrounded my boat and I am afraid I may have sucked some up?? Location? Fixes?
There is a water strainer under your aft cabin bed. Start by cleaning that out. You may need to re prime the system to get water through. To do that, just pull the hose off of the pump back by the strainer and when it shoots water, put the hose back on. Be sure to re fill the strainer with clean water after you clean it.
