Steering cable for 232
Could anyone tell me a part number or length for a sterling cable? I have a 2002 Rinker 232 with the 5.7 bravo 3. Thank you!
    2002 and if OE likely means it is NOT printed on the cable...
    it's without fortune you'll likely have to pull it first to get accurate measurement... for the love of all that's holy, pull a line through behind it as you pull it out.
    I think the trick is measure the cable housing then add 16", and get next length longer in foot increments... too short it won't turn corners; too long it won't turn corners...
    if i were to guess i'd guess 18'.
  • wissler08wissler08 Member Posts: 3
    Thank you for responding.
    If you have Teleflex it is now called Dometic SeaStar. Call their tech line
    1-800-DOMETIC. Andy
  • YYZRCYYZRC Member Posts: 5,462 ✭✭✭✭✭
    @212rowboat do these codes mean anything?
    Is that the part for a 212 or 232?
    edited June 2021
    first series is the part number.. the trailing two digits is the length... @YYZRC
    would need a 19' replacement cable...
    the problem you'll encounter with OE cables is they often are made for that boat specifically as the maker can get a exact required length (ergo a 18'4" cable) as opposed to the 19' and save a few dollars- over the process of ordering 100 cables, that makes a cost difference- and because of that OE cables don't carry the last two digits... now, this is for older boats (say, 2005 and earlier), and may not be the case anymore.
    the boat in question is an '02, and if it is OE cable, chances are it isn't stamped with the length.
    for that reason, pull the cable (not a difficult job BUT PULL A LINE THROUGH WITH IT!!!) and measure... I checked- it's NOT 16" it's 18" you add to the length of the shroud (plastic sleeve) and round up to the next larger number... (ergo, 18'4" would be a 19' cable for replacement).
    Thank you @212rowboat!
