There's a circuit breaker on the main panel in the galley, so make sure it's on. On the front of the icemaker, there's a rocker switch below the door - check that it's on. If no joy after checking those, the unit plugs into an outlet ... pull the unit out and check for power at the outlet.
Agree with these comments. Switch on the boats board, and there is an on switch under the front grill of the unit. But…. The ice maker is a timed cycle and one of the cycles is….. nothing. It literally seems like it is off for a half hour or so. I believe this is the heat cycle where it is warming the tray to pop out the cubes. Even if the unit is freshly turned on and warm, still has this cycle. So turn those switches on and make sure it has water close the door and give it 60-90 min. You may have ice!!!
