TV
Just purchased a 2007 360 Rinker and  I can not get any TV Stations. Any ideas
  • aero3113aero3113 Member Posts: 9,960 ✭✭✭✭✭
    Hello @414poplarct , did you do a channel scan on the TV? Sometimes this needs to be done to find channels.
    Also check to make sure you have an antenna attached to the TV. Do you know if the TV was original or did the previous owner install it? If it's a Majestic brand it's probably original equipment.
  • YYZRCYYZRC Member Posts: 5,498 ✭✭✭✭✭
    If @rando3113’s advice doesn’t work, check behind the breaker panel to see if the amp is there/working and if any of the coax has been messed with.
    You have the old TVs that can't pick up digital stations.
    Check the date on the TV. If it was before 2009, chances are it will not get HDTV. It could be a flat screen and not be digital ready.
    Yea the flat screen TV that came with my 06 342 was not digital, needed a converter box, I quickly updated it
    I have yet to get stations as well however after checking the digital TV reception website for where I am, it isn't very robust. May want to check that and see if you even have reception in the air to receive.
  • 414poplarct414poplarct Member Posts: 30 ✭
    Thanks for all the advice I'm putting new TV's in this weekend going to see if that is the problem the TV's are original in the boat now.
    Upgrade to satellite TV? Some units go on sale and are quite reasonably priced. Did that with our EC 360 - it was a great idea.
    Put new TV's in now I can get some stations thanks for all you help
