Light on the bow will not work
I have a 360 Express the spot light stopped working will not turn on or it will not go in any direction checked the fuses at the switch they are good any ideas on what to do. Also I'm able to change the overhead lights in the cabin and under the hardtop to LED with out rewiring
  • YYZRCYYZRC Member Posts: 5,498 ✭✭✭✭✭
    Batteries in the remote replaced recently?
  • 414poplarct414poplarct Member Posts: 30 ✭
    No I did not know they took Batteries were are they
    Do you have this remote? If so, the rubber cap just pulls off.
  • benvenuttiokibenvenuttioki Member Posts: 131 ✭✭
    And keep spares! Mine eats batteries.
    No my remote has a small joy stick. There is 2 fuses on either side of the joy stick there is 2 screws on it,I will take them off and see if batteries are behind it.
    What kind of batteries do those remotes take? How many batteries? I am about to head out on a trip and will pick up some spares.
    A23 I believe.
    edited July 2021
    Thanks! I think my ceiling fan at home takes the same  :)
  • Pat310Pat310 Member Posts: 606 ✭✭✭
    @414poplarct did you check for a breaker on the helm panel? On my ‘03 310 there is one for the light.last on on the right marked spot light
    @414poplarct if you have this Jabsco controller, there is no battery.
    Where my remote is located on my 280, the remote would get wet. I removed the remote and stacked two stainless washers behind each screw to get it off the gelcoat.
    Yes I do have the ITT Jabsco remote I'm going to pull of the remote and check behind maybe the wires are loose I Hope. But it is never that easy
    Good idea.  There are two plugs - power and signal.  Maybe one got pulled loose.
    It's the one on the right.
    Thanks will check this week
    Hi LaRay I did check and the wires got loose on the back working now now problem thanks for all your help
