Shocked by my propeller last night...
Dude_HimselfDude_Himself Member Posts: 596 ✭✭✭
Sharing because I'm still trying to understand this one, but want to make sure no one else nearly ordered $1k in new hardware because of a bad cord.
I spent the day replacing springs on the triple axle trailer, using a quality heavy-duty extension cord to run an angle grinder. Barefoot. All Day.
When I wrapped up I moved the same extension cord to the boat to run the HVAC blower while I worked inside. I noticed a loose socket by the sterndrive and bent over to get it: when I leaned against the propellor I found myself unable to let go. We had a heat advisory (it was 107°), and I'm a former GC used to working in it all day, but getting older. No big deal, I pushed a little harder and got back up.
Must be woozy.
I went back to the ladder, and guess what? My left arm tingled - I must be having a heart attack or stroke! %$^@$%^ CoVID got me, kids! No, suddenly that pain stopped when I let go. Hmmm.
Spent a few hours with a voltmeter confused:
  29VAC on the ladder to concrete
  48VAC on the sterndrive to concrete
  The boat is on a trailer, but sitting on wood blocks - that's not causing it, right? (I was HOT).
Started flipping breakers, moving upstream from the battery charger. 48VAC on ground/negative anytime the boat is plugged in. New (to us) house: maybe the garage wasn't wired right? Nope, that's not it.
Then I checked the cord: it had been yanked hard enough the ground wire in the male end pulled out, and a single strand fell across the hot connector inside the plug housing (also, an employee terminated this 12 years ago - notice the extra cut on the neutral wire insulation?)
48VAC from ground to "concrete", while plugged into a GFCI protected breaker. Never tripped.
So here it is: be careful! Even a GFCI won't protect your dumb, tired a$$ from stupid.
    Good catch!
    A GFCI is a mechanical device and any mechanical device can malfunction. You can never be to careful dealing with electricity............ Just say'n
    Does the GFCI work when you press the test button?
  • Dutch320Dutch320 Member Posts: 83 ✭✭
    GFCI’s do go bad and have a somewhat high failure rate. If you received a shock of any kind the GFCI failed. They are designed to literally be able to throw a toaster in the bathtub and not get a shock. They do sell a tester that checks a GFCI but for the cost just replace it.
    Should also add: GFCI is new (March), tests properly (internally), and trips with a simulated GF.
    Good catch
    Good find!  These are the types of things too many people don't notice and end in tragedy.
    edited August 2021
    Ok. Worked over the full boat electrical system with a voltmeter, gfci tester, and screwdriver (tightened terminals). Found a few loose grounds, but otherwise it's a safe boat - important as its going on a lift real soon!
    At some point over the next two days lightning struck my garage (#&$$%!!) and blew the trailer wiring to bits. No $hit, FML, melted the junction box and wiring into a ball and fried the EoH brake pump.
    Check out the cool fractal pattern:
    It's August. I've replaced springs, equalizers, tires, wiring, lights, brakes, and fluid.
    Boat hasn't seen the water, and I'm still working on the generator service.
    Don't do boats. Just say no.
    I Did
    We must have a good forum-
    You were running an angle grinder while barefoot?  Brave soul!
    I agree. He should at least be wearing a pair of flip-flops
    Check out the cool fractal pattern:...
    That's interesting!
