Normal Running Teperature
I just purchased a 2008 Rinker 330 EC. I love it but I have a question. I have twin Mercruiser 350 MAG seacore engines. I read that the normal running temperature should be 170 degrees. Both my engines run at slightly above, 175 to 180. Should I be concerned or is this ok?
  • aero3113aero3113 Member Posts: 9,964 ✭✭✭✭✭
    Welcome to the forum! I have the exact same boat!!
    My engines run the same temps as yours.
    edited August 2021
    You can’t trust the Faria gauges 100 %. Only way to get accurate readings is to go digital.
    Mine show that temperature on the gauges as well. When running with my VesselView Mobile app, the temp on the app is around 162. I trust the app more than the gauge.
    Yep my 342 with 350s ran the same. They matched on both sides so it never gave me concern. The new owner of that boat put in vessel view and found that the gauges were 10 degrees high.
    Don’t you guys think that’s kinda cool? A car runs about 210??
    I also have 350 MAG Seacore (2014) and they run at 162.
    Not at all. The thermostat is a 160* stat.
    Yea I had thought RWC merc ran around 140-145 and FWC merc ran around 160-165?
    Just for you @Handymans342 my diesels run at 185F on the dot!
    I know when the thermostat sticks open on a car it runs cool but the computer thinks it’s cold and runs a richer program. Maybe the computer is programmed on boats to see 160
    Funny, my port thermostat stuck open this weekend. Once I got up on plane it must’ve cleared something and was back up to my normal running temp.
  • YYZRCYYZRC Member Posts: 5,499 ✭✭✭✭✭
    Most cars don’t run at 3500+ RPM sustained.
    That’s irrelevant
    Most marine engine thermostats are either 145F or 165F gas or diesel.
    Mine were 180
    I said most
  • PickleRickPickleRick Member Posts: 4,388 ✭✭✭✭✭
    edited August 2021
    140 in salt to prevent  salt build up and 160 in fresh water.
    This is for raw water cooled motors.  Although many report using  160 in salt water for decades without issue.
    My diesel runs 175 at idle speeds but 210 at wot  which is well within range for my VM Diesel. This is closed loop.
    @Handymans342 is correct that the same votec motors used in many of our boats  (closed loop) are identical except for the cam and some marine rated electronics as the 5.7 votec found in the same year 1500 gmc pickup.   They also run about 220.
    Maybe someone with closed loop cooling can chime in and tell us what temp their 5.7 motors are running.
    I was always under the impression that the newer votec motors ran more efficiently at 200 to 210 vs the 190 of the 4bbl  4 bolt main days of small blocks.
    Mine were 180
    I can’t believe you missed the diesel reference above….
    My 330 had 5.7 with closed cooling and 160 t-stats. 350 has 6.2 with raw cooling and 160 t-stats.
    Thank you!  Good info!
    My 330 with 350 mag raw water cooled run 154-156 on the vessel view mobile.  The gages read something like over 175.  Love the VVM.
    WoW! That’s a huge difference!! I wonder what I’m actually running. I guess I can hook up my Rinda and find out.
  • BmaggiacBmaggiac Member Posts: 30 ✭
    I feel better now. Thanks for all the great feedback!!!
