2001 vs. 2002 Measurements 310 FV for winter cover
Rinker310_LIRinker310_LI Member Posts: 22 ✭
I can't seem to figure out why winter cover manufacturers only stock template sizes for the 2000,2001 Rinker 310 FV.  If you use any of the major sellers 'find a cover' option you can find the 2001 310 FV but if you select 2002 310FV there will be no matching size winter covers.  I am pretty sure the dimensions of the vessel did not change from 2001 to 2002.  I have a 2002 310 FV and am looking for a pre-made winter cover and can find none specifically made for an 02.  Anyone know if there is a difference ?
2002 Rinker 310
Best Answer
    Answer ✓
    Very minimal changes from 01 to 02. Dash is one of them.  Also edit to mai engines with smart craft. Hull is identical.  This takes me back to the times I was looking to buy one and got a 2002 310.  Great boat!
    I had the same issue buying a cover for a 2008 330. Took a lot of back and forth to convince Fisher it is the same as a 2009 340.
  • Rinker310_LIRinker310_LI Member Posts: 22 ✭
    very frustrating !  I have even contacted Rinker / Polaris to see if I am missing something.
    2002 Rinker 310
    Well you certainly won’t hear back from Rinker. But regardless it’s a winter cover which is about as form fitting as a muumuu.
    @coverguy2 can you advise?
    edited August 2021
    I have a 2003 and I am sure its the same as 2001/2002 as the 2004 or 2005 charged the shape if I recall. Happy to help to confirm measurements.  PM me @Rinker310_LI
