Mid cabin light switches not working
My 06' FV 360 just developed a problem with the mid cabin lights not turning on. All the other lights on the boat work fine. The switch on the panel is on position. The light switches (3) for the mid cabin were working fine, and then intermittently, and then just stopped turning the lights on within two days. This is my first boat and first post. I don't know where to start, so any help will be much appreciated. Thank you.
    Welcome to the board.
    Sounds like a loose connection to me...that slowly worked itself completely free.  I'd grab a multimeter and check the switches for 12v and start from there.
    2002 - 270FV Mag 350 B3
  • YYZRCYYZRC Member Posts: 5,548 ✭✭✭✭✭
    There’s likely a molex connector behind the switch. Maybe it came loose. Pry the chrome switch plate cover off with a flat blade screwdriver and remove the switch assembly. Pull the bundle of wires until you find the connector.
