2006 Rinker Captiva 262 Bowrider- Anchor question
Looking to get a new anchor.  What would be recommended for this size boat?  #8 on Overtons?
    edited September 2021
    8lb anchor a bit light for 28' (6000lb) boat. Flukes are probably best bang for your buck.
    Lots of anchor charts out there. Flukes & Plow anchors seem most common.
    I use a 25lb windlass anchor & an 8lb stern throw anchor. (31'4" boat length) Make sure you have some length of chain rode on each.
    Mantus Anchor Imperial Recommendations
    @JWalker welcome to the forum.  I agree an 8-pound anchor is not the answer.  If you talk to enough boaters -- the longer they've been boating, the heavier the anchor/chain they recommend.  Chain is your friend.
  • JoeStangJoeStang Member Posts: 1,144 ✭✭✭✭
    8lb is good for a stern anchor, useful for when tying up with other boats and keeping the boat from swinging around. I have that with 4' of chain and it holds great, but I always set it by hand since we're in waist-deep water.
    I use a 13lb with 4' of chain for my main anchor, and I've got a 276 cuddy. Its NEVER let loose, even in serious storms. I dont have to set it by hand, I can throw it out, back the boat down, and it grabs perfect every time. I'm in sand bottom though, so that makes a big difference. If you're in mud or soft bottom you'll need more anchor, line, and chain than what I use.
    2013 276 Cuddy ~ 350 MAG / B3
