Shifting into drive problem from idle
On a 2013 Captiva 276 CC w a 5.7L Mercruiser Bravo 3, I am having trouble shifting into forward drive after initally leaving the dock , putting in neutral, then trying to go again. Engine just revs then all of a sudden bangs into drive. Does anybody have experience with anything like this ? Any help would be appreciated. Thanks in advance
Best Answer
Spyderweb
Member Posts: 960 ✭✭✭
I had this same problem. Initial fix was to replace the shift cable. That worked for awhile, but symptoms returned. Marina ended up replacing the cone clutch. That solved it.
On the throttle itself when removed I could see as I moved it forward it was delayed engaging the forward gear but very quick to engage reverse so it need to be adjusted forward more.
