Still searching for answers.
. I posted a query about a 5e that would not start. It had no spark or fuel. The troubling thing was it started 3x during trouble shooting. But the other 47 times it just turned over. I don’t believe it is LOP sensor as I have replaced oil and filter and checked level w dipstick unscrewed. I am wondering if it could be a faulty rocker switch and control board, hence the intermittent start 3 times. When I rock it back and forth it doesn’t seem to really click. My question to you would the rocker switch cause the unit to not start but indeed turn over? And if the the panel rocker was defective would the remote switch suffice and essentially bypass the panel switch? Perhaps I’m grasping at straws but I am really scratching my head in this one. - clear
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwj9gJmDoZbzAhWjl-AKHfffCPgQFnoECAUQAQ&url=http%3A%2F%2Fsailing.com.br%2Floja%2Fmanual%2F5-7.3op.pdf&usg=AOvVaw2aKVo5APJ5vgeuTLkxm-sH
https://rinkerboats.vanillacommunities.com/discussion/2327/kohler-5e-7-3e-manuals-install-operation-and-parts
https://www.partsfortechs.com/asapcart/index.php?main_page=product_info&products_id=464
Might be worth a shot. Another item might be anti-diesel valve in carb. Not sure if that cuts out spark though
