Bravoitis soultion advice
Mercury2005
Posts: 141 ✭✭
In an effort to fix the Bravoitis issue I have a plan that I need discussion/advice/recommendations for.
I realize I could remove the drive, replace the intake water hose, fittings and related parts but that is labor intensive with no guarantee it will fix the problem, plus getting to the fitting on the inside of the transom plate is nearly impossible.
My 27 FV has a generator with a thru hull water inlet/seacock which is 1" i.d. hose size.
If I were to replace that thru hull with a 1/1/2" and corresponding seacock, then run a tee fitting one side reduced to 1 1/4" to feed the engine and the other side reduced to 1" to feed the gen.
My question is, will this setup provide enough water intake for both the engine and gen assuming bioth are running at the same time?
The only other option is installing a separate thru hull just for the engine.
Looking at the seawater pump, the inlet hose size is 1 1/4" O.D. with an I.D. of 1", where the output side is 1 1/2" O.D. with 1 1/4" I.D. And from what I read the hose size from the drive is less than 1", about 5/8".
Seems odd that Mercury would not size everything the same size, ow well.
Thanks to all in advance
I agree with @Alswagg - fix the problem. Replace the hose and fitting. If you rig something from the genny intake, you're inviting pain and heartache.
The unofficial definition of Bravoitus
"The crushing of the forward end of the water hose and retainer of the belle housing to transom plate water hose, which will restrict water flow into the sea pump"
FYI, Merc fixed the flow restriction problem by redesigning the thru-transom fitting. If/when you eventually need to replace your boat's transom assembly, the new transom assembly will include the redesigned fitting.
Your boat's an '06 ... is your transom assembly leaking sea water into the bilge? Do you have corrosion on the steering pin, and excess play in the steering?
Handymans342, water only goes thru the lower gearcase for only about a foot then into a rubber hose. Since the lower gearcase is in the water it's already being cooled.
LaRea, Thanks for the insight on the hose size, makes sense. No leaking at the transom plate but do have a little play in the steering. Will check on steering pin corrosion.
I did go ahead and temporarily re-route the water intake hose from the generator directly to the seawater pump and it did resolve my problem. My water pressure is where it is suppose to be and engine temp is now normal.
I plan to install a dedicated thru hull just for engine and bypass the thru-transom feed.
Davidbrooks, Exactly why I am not 'doing it the right way'. When I looked at removing that inner fitting, I would have to remove part of the power steering assy just to get at the fitting and like you said, no guarantee it would come off easy.
If I ever do decide to pull the drive I will plumb up a system to use that water as a drive shower.
Thanks to all who responded, what a great group of Rinker owners.
It's 15 years old. Based on what we've seen here on the forum in recent years, it probably doesn't have much time left. If there's any water coming in from the steering pin, that's a certified death spiral. Here's my transom assembly when I replaced it after 14 years of service in a well-maintained fresh-water boat.
Alswagg, I'll keep you and the group posted with pics when the installation is complete.
Not to mention, it was always a struggle getting the pumps primed after launching the boat. Never had that problem on my current boat (without dual pickups).
What am I in for that I don't know about, @LaRea ?
