Anchor Chain Piling Up
kordokordo Member Posts: 251 ✭✭
I have had issues with my anchor chain (110 feet) piling up and jamming my windlass.  I finally decided to take a look at the installation and noticed that the hole cut in the deck was not according to the template supplied with the windlass.  The second pic shows what I assume was the factory installation, they drilled 3 small holes in a row, instead of the 3" hole shown in the template.  This is the Lewmar Pro-Series windlass.  I removed the windlass (an awkward job) and drilled a 3" hole as shown in the first pic.  The chain now falls in a shorter pile and doesn't jam the windlass.  I think the larger hole allows the chain a bit more room to fall in a wider circle and therefore a  shorter pile.  If you are having a similar problem, it might be a good idea to check on how the factory or previous owner installed your windlass.
  • YYZRCYYZRC Member Posts: 5,594 ✭✭✭✭✭
    edited September 2021
    Brilliant!  Mine piled up and jammed last time out (had never happened before) and it was annoying to say the least.  I only have 60' of chain, though.
    Ditto -- I have 60 feet and it does jam up every now and then.  I might have to try this solution.
    @kordo what was awkward about removing the windlass?  Just reaching the bolts?  Gotta be a 2-person job, right?
  • kordokordo Member Posts: 251 ✭✭
    LaRea, yes, just reaching and undoing the nuts and then putting the nuts back on along with the washers.  Did it myself and only suffered stretched muscles and a few scratches.  A further note, I was pleasantly surprised at the more than 2 inches of depth of the platform that the windlass sits on.  Needed to charge my portable drill a couple times to drill the hole.
