Tundra TJ22AC Freezer plastic door replacement or other solution.
Good morning everyone, hope everyone had a great season. Our plastic freezer door in our cockpit fridge keeps falling , some small plastic part that are holding the door are partially broken. This is a tundra fridge tj22ac .Any suggestion where we could find a freezer plastic door replacement or any suggestion / solution on how we could make the current hold better and still able to open/close.
  • GrahamuGrahamu Member Posts: 919 ✭✭✭
    If you were in Canada I would suggest you call Bob at Northland Supply Co in Keswick Ontario
    You need to defrost that unit. Way too much ice build up to be effective and the ice is popping off the door. You may be able to pop it back on with some pressure at the hinges if you defrost. We defrost our fridges every 8 weeks at the most, really should be 4-6.
