Lost power to trim tabs on my 342
I know when I did it and I held the switch to long, so are there fuses and breakers that aren't in the couple of obvious places?
    Other than the breakers under the dash, there are no in-line fuses on my 2003 342 for the tabs.
  • scottb3200scottb3200 Member Posts: 46 ✭✭
    I know this is a old post
    But am new here same thing happen to me on my 320 so can you trip fuses by holding down trim tabs too long
  • Captain_RobCaptain_Rob Member Posts: 19 ✭✭
    I too have 320 with only power to 1 tab any help would be helpfull
    You could have a bad actuator. Cracks/leaks will kill one. I had this happen...replace both if one is bad, the other is probably not far behind it.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,798 mod
    I agree, if only one went bad, it's probably the actuator.  If both went bad at the same time, probably something else.  The actuators are pretty simple to replace (did one on a friend's boat a couple weeks ago).  Make sure to use some 4200 when sealing back up and take the upper plastic mount off so you can get a good new seal around the cable.
  • raybo3raybo3 Administrator Posts: 5,565 admin
    I am not crazy about the Lenco tabs. Electric motors in water does not do it for me. I have replaced mine a number of times. I only get about 2 years out of them. I am changing over to Bennett hydraulic tabs. .
    Hummmm..... since 2006 no issues.... hope I am not jink'st. ..
    Go to lenco's website and get the trouble shoot guide. It is the only way to know what is actually wrong, There are many reasons why they might not work. I love Lenco and when I did have a problem they were great with helping me diagnose and they even sent me a new part for a 5 year old boat for free.
    Bella Sabrina II  370EC
