How do you drain the water tank for the sink/aft shower
I have a 2008 276BR i just bought and the water tank for the rear transom shower and sink is pink. pretty sure that means it was winterized. No need for that here in phoenix AZ. How do i drain the pink stuff out of the tank? Thanks in advance
  • YYZRCYYZRC Member Posts: 5,603 ✭✭✭✭✭
    edited October 2021
    Run the water until the tank is empty, then add fresh water and flush a few times.
    Basically just run the shower/faucet until empty, then add fresh water and repeat until you get clear water out of your shower head.
  • FeelinNautiFeelinNauti Member Posts: 14 ✭
    thanks will do that, didnt know if it had low point drain like the rv
    When you refill the tank after the pink has been ran out, just put 3-4 gallons at a time in then run that out. Do it a few times and you will be good to fill all the way.
