Hot wire connected to smart craft accessory?
pcmpetepcmpete Member Posts: 114 ✭✭
Does anyone what Rinker wired to my starboard accessory block that should be always hot.  The cable goes out the far side of the block into a protected sleeve then runs down in to the wiring nest.
    Bilge pumps?
    2002 - 270FV Mag 350 B3
  • aero3113aero3113 Member Posts: 10,019 ✭✭✭✭✭
    edited January 2022
    Bilge pump and high water alarm float?
  • pcmpetepcmpete Member Posts: 114 ✭✭
    edited January 2022
    Would they take power from the helm area and run wiring back to the bilge where the battery is?  Seems like a lot of extra work.  aero3113 said:
    For some reason I was thinking that pic was in the bilge.
    Could it be power for the head unit in the cabin?
    I am wondering if it power for the trim tabs….
    I guess I will have to disconnect one of the cables and see what stops working.
    It could be for the auto retract function on the trim tabs.
  • YYZRCYYZRC Member Posts: 5,535 ✭✭✭✭✭
    edited January 2022
    I think that’s the orange wire? On my boat, the auto retract is wired to the ignition.
    My tabs retract when I key off my port motor.  Those wires on the starboard terminal are hot until turn off battery
    Definitely not bilge pumps or stereo.  They have dedicated circuits.  Plus, you wouldn't want to connect anything that could draw a lot of power and potentially interfere with the DTS controllers.
    It could be the VHF radio, which you'd want to always have power.
    I took apart my wiring harness when i put in new guages a few years back.  The one thing i did notice is that there are a lot of components that share both + and - wiring.  You will as you start unwrapping the wiring harness that the power lines get tied in together further up the line.
    I am having DTS issues, but on my Port Lever.  I wonder if this has any connection to this issue.
      I will be digging deeper into this more at the weekend when I change my Lenco Trim Switch which stopped working.
    The two DTS feeds (red/black wires in a light gray sheath) need solid connections to the batteries.  The factory wiring is one to each starter battery.
    Switched or direct to batteries?
    They are direct to the battery.  Should be a 40-amp inline fuse close to the battery, so check that too.
