Rinker custom Guest battery switch with 2 knobs and built in breaker panel
echandler1971
Member Posts: 249 ✭✭✭
I plan on ringing out the lines this March before reinstalling my 4 battery banks (bow thrust has its own). The boat has been ours for only a year. Wiring around the batteries is atrocious. I’m finally catching up and figure out that area while I have the advantage of dead cables.
I have a few questions:
1. Left knob turned to the left connects one of two starter batteries and right knob to the left I assume connects
to the other starter battery?
2. Two middle switches connect to the 2 battery house?
3. Anyone have a manual for this switch, given it seems to be a custom Guest/Rinker venture?
4. I’m replacing the isolator with the ProIsoCharge btw, but other posts reference that along with pros and cons. Still, it matters which battery is associated with a specific alternator on that isolator, making it important I get the wiring right.
Dan of Steel
'05 Rinker 360 Fiesta Vee
I never understood the hatch motor override circuit until I took everything apart and drew a circuit diagram. Details are here:
https://rinkerboats.vanillacommunities.com/discussion/8162/how-to-open-the-engine-hatch-with-the-batteries-disconnected/p2
Also, be careful with the small circuit breakers. I accidentally cracked one of mine, and the replacement part was not cheap.
