Painting Outdrives and Tabs
echandler1971
Member Posts: 249 ✭✭✭
I have a few questions to bounce off of the knowledgebase here. Early April, I plan to carefully-disassemble the 2 transom mount assemblies into 3 parts (x gimbal, y gimbal, and trans assembly left attached to transom), sand blast them, prime and paint. They are looking pretty bad with the transom plate being riddled with unreachable barnacles. The outdrives are in indoor storage who knows where at the moment, but I'll do the same to them when the marina reinstalls them. Anywho:
1. I would remove the zincs, but it has me wondering if the zincs need to be in contact with metal to some degree when reattaching them, or can they be attached to painted metal afterwards? I'm assuming that if anything, the bolts holding them on would make this connection if it was necessary. This question would also apply to the trim tabs that will be getting the same treatment as above.
2. My plan is to sandblast with medium grit AL oxide, prime with 10% thinned InterProtect 2000E and then apply Trilux 33. Does this seem like the right thing to do?
3. I'm wondering if the mount for the fan on the bow thruster should be treated similarly, rather than just getting bottom-painted like it is now.
Thanks
Thanks
Dan of Steel
'05 Rinker 360 Fiesta Vee
I'm not sure Trilux is durable enough to serve as the primary coating. You might need some other product, with Trilux as a final anti-fouling layer. The factory finish is a hard coating -- probably some sort of epoxy.
