Hatch stopped working
rasburyrasbury Member Posts: 9,043 ✭✭✭✭✭
While changing plugs I pulled the hatch up/down asy to get it out of the way. Did not shove it around, can't imagine enough to pull any wires loose...?
  • LaReaLaRea Member, Moderator Posts: 8,086 mod
    On mine, the usual suspect is the plug at the hatch motor.  Unplug and check for corrosion.
  • rasburyrasbury Member Posts: 9,043 ✭✭✭✭✭
    Plug? I did not see a plug or connector..must be up in the harness..maybe I pulled it lose..
    I'm talking about the connector at the bottom of the actuator, a few inches away from the motor (down in the bilge).  Try unplugging and replugging it a few times.
  • raybo3raybo3 Administrator Posts: 5,625 admin
    My problem was a bad DC neg connection on the back of the transom
    It was end of the day and a quick look did not see any connectors..but their is loom and the wires are not exposed. It worked fine with no issues, I moved it for access and must have pulled it loose....I hope!
    So how the heck did you figure that out!
    @rasbury the hatch would only go up (very slowly) about 3 inches but would come down pretty easy. I used a jump pack and it went up pretty quickly. So I knew it was a wiring problem.  While in the ER I noticed how corroded the negative block looked so I cleaned all the connections. After that the hatch worked perfectly. Note: it was the last wire on the right for the hatch.
    @rasbury I replaced my neg block this winter and about 4 of the wires just fell apart when touched. This is a great place to start.
    Mine as I said worked fine until I moved it to lay down on that side to get to the plugs...I am hoping I just pulled a wire...
    It was the connection on one wire pulled apart. Kind of curious as it did not for sure  look like what I would would hooe the oem connection would look like...any way..back to working.
    edited March 2022
    .....first sign of erratic behaviour involving electrics I go straight to the ground wires which has saved me a lot of time and money. Not just corrosion but loose screws on panel backs, behind the dash and the dreaded blocks.
    Yes Michael, we always jump to the worst case scenario when often a group d or corrosion issue...I had moved the whole asy and my first thought was a pulled wire out of the motor which would not have been good so I got lucky!
