Trim
rasbury
Member Posts: 9,027 ✭✭✭✭✭
When I first bought the boat, the trim was a little iffy- the up would only work trailer position...but the down worked fine. Al had mentioned that the trim sensors setting may have had something to do with it...now to go down you have to up/down the switch to get it to go down, up seems to work as described.
Any quick barrow it down checks? Is the switch replaceable or I'm sure a boat buck asy replacement? Almost sounds like a bad ground, just not sure where to start the process.
