Galley Pump
Hello All ,
I have a 2019 290 Ex. Picked it up after winter storage. The guy at the marina said I just had to flush the antifreeze from the fresh water tank and I would be good to go.
When I put water in the tank and turned the galley pump on the water just goes into the bilge from what looks like a relief hose.
There must be some valve they left open when they winterized the boat. Does anyone have any idea what the issue could be? Is it a valve somewhere that must be closed?
Thanks in advance for your help
    The hot water tank has a pressure relief valve on it and a water drain on it.  Either one could be open.
    2002 - 270FV Mag 350 B3
    Yes - easy fix.  Look for a water drain like this:
  • ChillTimeChillTime Member Posts: 5 ✭
    Thank you both. I traced the drain hose back the shut off knob.  Turned it off and that fixed the problem.
    Thanks so much!!!
