Lost 110 at the outlets?
I have a 2005 FV270.  Plugged into shore power, have 110 at the control panel.  The microwave is plugged into the outlet on the rear of the control and it works.  The oulet on the front of the panel and the outlet behind the helm do not work.  I have toggled the outlet breaker on the front of the control panel and the switch by the helm outlet.  No juice, senior moment, brain gas?  Seeking advice.  Thanks
    Those outlets should be GFCI...did you try resetting them?
    2002 - 270FV Mag 350 B3
  • goalie59goalie59 Member Posts: 356 ✭✭✭
    As skennelly says if one of the gfci 's are tripped they can cut power to the other receptacle's.
  • pinevuepinevue Member Posts: 9 ✭✭
    GFCI does not reset, I suspect a 17year old outlet has served out its time. Ordered a new GFCI.
  • Pat310Pat310 Member Posts: 606 ✭✭✭
    Just throwing this out there. There is I switch on the panel to turn the outlets on
    Life expectancy is 15-25 years, probably not top of the line when installed.
    They aren't much better today. That little board in there is China
  • AtlanticJimAtlanticJim Member Posts: 27 ✭
    Curious if you solved this problem because I have the same thing going on and will pull the panel this week to see if the GFCI broke when i was testing it.
  • YYZRCYYZRC Member Posts: 5,492 ✭✭✭✭✭
    GFCI should be at the closest outlet to the panel.
     Mine is in the head outlet under the sink
  • bandkbandk Member Posts: 9 ✭
    On my 2007 350 my forward berth AC outlet was dead.  Found the GFCI outlet under the electrical panel was wired backwards.  Power was wired to load side and downstream outlets were wired to line side.  Swapped the connections (actually in-line connectors) and everything worked.
