How do you use your batteries?
I have a FV 270 with two batteries. One is the house (deep cycle) and the other is a starting battery.  Here’s the way I use them: I always keep the selector on battery 1, the house deep cycle. Both batteries will charge on the shore power or alternator. The starting battery is just insurance in case I were to deplete the house battery when we overnight or hang out all day on anchor. Am I doing it correctly?  Seems to make sense to me.
    Similar except I keep mine on the starting battery.  When anchoring I switch to #2...and back to #1 when I pull anchor.
    2002 - 270FV Mag 350 B3
    Hmm, I’ll have to consider that.
    So, what skennelly is doing is what I used to do with our 240.
    Yep
    Guess I’m doing it backwards.  I’ll change my strategy.
  • JoeStangJoeStang Member Posts: 1,144 ✭✭✭✭
    I would do it as you have been, that way if you forget and run down the battery while anchored you still have the starting battery at 100%.....
    My switch is On - Off - Combine, so really the same as yours just different labeling. On is just house battery and I've killed it lots of times with the stereo and the starting is always perfect.
    2013 276 Cuddy ~ 350 MAG / B3
    Thanks Joe.
