Caulk question
Hey guys. I’ve just installed my extended swim platform and when I was caulking everything I ran out. They provided a tube of Sikaflex 295uv in white. My local marine store doesn’t have any white in stock. They recommended 3m 3000 which I tried but it’s waaay to gummy. Any suggestions for any alternative to the sikaflex?
     Try 3M 4000 UV, I use it on all of my above the waterline projects.
  • JakesRinker300JakesRinker300 Member Posts: 91 ✭✭
    Aero what’s the consistency of the 4000 like?  The tube of 3000 I tried tonight was really gummy/stringy. When I laid down a bead and tried to smooth it out with a damp finger tip, it was really sticky/gummy. Made a real mess.
  • YYZRCYYZRC Member Posts: 5,594 ✭✭✭✭✭
    I use soap when smoothing 4000.
    Swim platforms direct ? How did it line up to the back or the recessed platform
    @JakesRinker300 4000 isn’t gummy. When I seal, I tape off both sides of where I’m sealing then use my finger to smooth it out. Perfect line when the tape is peeled off.
    Swim platform ultra located here in Canada. I’m not gun lie. I had to do a lot of fitting. The curved profile across the back of the boat was close but where the platform fits against the profile of the factory platform, I spent likely 6 hours just on that.
    That 4000 / UV4000 will get moldy.
    I never had an issue with mold?
    I've not had a mold problem, but mine has been yellowing. Has not stayed a bright white.
    Mine has gone all discolored and really collects dirt.
    Oooookay so the 4000 is out? Lol
    4200 is not UV protected and will yellow. 4000 is. I have areas that I used 4000 on and it has not yellowed. It has been in the sun for 6 years.
    Greg in your experience with the 4000, is it gummy?
    I didn’t think it was gummy. I taped everything off, placed the caulk, smoothed with a wet finger, then removed the tape. Since it is a sealant, it is sticky.
    The 4200/4000 is really not meant to be a caulk.  Made that error caulking/resetting the u-channel for my canvas.  Should have used the BoatLife caulk, it won’t yellow or mold.
    I managed to get the platform manufacturer to overnight me a tube of the 295uv white. I got the caulking finished and we’re in the water now. Thanks for all the feedback!!
