Kohler 5e generator and air conditioner
Bayrunner
Member Posts: 177 ✭✭✭
My generator had a tune up, fuel filter, oil change last year. This year it will tune over but will not start. My best guess is the coils need to be replaced. Can anyone have this problem and can provide me with some options. My 12k BTU air conditioner has a bad leak and will need to be replace. Any good recommendation on what brand works well. I have a marine air system, taylor made.
Best Answers
Dream_Inn Member, Moderator Posts: 7,979 mod
For AC, @aero3113 got this one:As for the generator, coil is very easy to change (I keep a couple spares) but I'm not sure I'd jump to that quickly. It will start with even just one coil of the 2 working. Plugs are always easy to change as well, that may be the place to start. Does is sound like it is trying to start? Is fuel turned off to it?You need to get her running so you can bring her up to Rinkervous this year!!
aero3113
Member Posts: 10,085 ✭✭✭✭✭
Did it run after the tune up? If not, the fuel line may need to be bled.2008 330EC -
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
Make sure the fuel valve is on for the genny. If they ran it dry for the winter…be patient getting it going, takes a bit for the fuel to get to the carb. Don’t o er crank the starter either: it will overheat.
