2006 Express Cruiser
Hi all.
New to the site.
Thinking of moving up over the winter from a 1999 212 Festiva to a 2006-2008 250 E.C.
Any thoughts, comments or advice would be helpful.
Thanks
Best Answers
jklein
Member Posts: 49 ✭✭
I love mine - 2006 250 EC. I upgraded from a 1989 22 footer and it is worlds apart. My only recommendation beyond the obvious (get as clean a boat as possible) is look for the bigger engine. I have the mag 350 and fully loaded - people,fuel,water,waste it takes a while to plane. Other than that I couldn't be happier. Some items to expect (based on my 1 season ownership - new batteries, fresh water pump and new hot water heater. The only mechanical I had was a water pressure sensor for cooling and it was a faulty sensor. Good luck. -
TikiHut2
Member Posts: 1,431 ✭✭✭✭✭
Plenty of 270s around and you get a bit more beam which helps all the way around. It was what got us in ours and we really like it. Actually typing this while anchored out on-board for a long weekend. Just a thought, and good luck in your search.
Mike2004 FV270, 300hp 5.7 350mag MPI Merc 305hrs, 2:20 Bravo3 OD w.22p props, 12v Lenco tabs, Kohler 5kw genset, A/C, etc.etc...Regular weekender, Trailer stored indoors, M/V TikiHut, Sarasota, Fl
We use a tri-axle trailer w/dic brakes but there are others here who pull their 270 on a HD tandem just as well. I use a 3/4ton Suburban with a gas 6ltr Vortec which is fine at 60-65mph in Fl but I'd want a bit more truck if I was pulling where it was hilly, really often or further than 2-300mi. It stops in a straight line and pulls like it's on a rail so trailering is pretty easy once you get the system down and then every lake in the state (or further) can be yours in just a few hours......and you'll also have your own private apt. Have fun looking.
Good luck in your search. Mike
Here's our rig packed for Labor day weekend:
