Engine compartment blower
Grahamu
Member Posts: 923 ✭✭✭
Just completed a 5 day trip and at the end noticed my port side blower not working. Didn't have time to check it so wondering if it's a 3" or 4" blower and brand. Would like to take one to the boat next weekend,
We've got white PVC pipe for some sections the blower - really slick if you can work it in. One less thing to fail.
I think this board has the cleanest engine bilge areas on the internet.
@oscar1 I would not add an intake blower. The exhaust blowers pull air from the lowest point of the bilge, because that's where gas vapor will fall. An intake blower would stir up any gas vapor that might be there, and distribute it all through the engine room.
But in a diesel set up where there isn't enough clean air intake you won't run the blower before starting, you'll install a thermostat to turn on the largest blower you can find so she can bring in fresh air when it gets too hot. Diesels run best on clean air and clean fuel. The issue being the engine hatch gets so hot the IAT the engine sufferers performance wise, if it's bad enough she'll not have enough air that it will choke the motor. The later of the two will be unlikely when putting small diesels in place of a couple v8s. On newer electronic controlled diesels the intake air temps are something you can see on your data log.
The only way to find out if you need it or not is to run it. A cheap harbor freight temp gauge will work if you don't have a way to log the IAT.
They move a ton of air.
