Losing anti freeze , overheating
paparuxpaparux Member Posts: 4 ✭
2004 342 fiesta vee. I’m constantly adding antifreeze. I don’t see any visible signs of leaking. An hour trip I lose about a quart. Longer runs cause overheating. I don’t smell it burning or any smell at all. All help greatly appreciated.
  • aero3113aero3113 Member Posts: 10,034 ✭✭✭✭✭
    edited July 2022
    It’s mostly likely your heat exchanger and it’s leaking, antifreeze is going overboard with the raw water. A head gasket could be the culprit also but you would probably smell it then.
    Many local auto parts stores will rent you a pressure test kit for a radiator.  Pressurize it to the psi on the cap and wait.  I think it's 13 or 15 psi.
    Good point Rick. I've done this before from Auto Zone, was free for 48 hrs and had multiple caps to find the right fit.
  • paparuxpaparux Member Posts: 4 ✭
    @aero3113, I believe your correct, what is the best way to test for that? I don’t smell it burn and nothing shows up in oil or bilge pump area. Is there away to check the heat exchanger?
    edited July 2022
    Yes, you can pressure check them but would have to be done off the engine. You can check the head gasket with a simple compression check (but sounds like it’s you heat exchanger).
