Rinker 290EC Smart Craft Analogue Gauge Interface
Hoping someone my have some suggestions.
My 2013 Rinker 290 has smart craft analogue gauge interface with Faria gauges. Main Gauge is 4 in 1: Fuel , Battery Voltage, Oil Pressure and Temperature, starboard Gauge is RPM and Engine Hours, port side of main Gauge is Speedometer and smaller gauges with Transom tilt and depth finder.
4 in 1 Gauge:
- Fuel reports properly (Filled it with gas and reports full)
- Battery Voltage Reports properly
- Engine Temperature reports no engine temp
- Oil Pressure reports no oil pressure
Single Gauge with RPM and Engine Hrs.
- RPM reports 0 RPM
- Engine hours report properly
Speedometer does not report speed
Depth Finder reports properly
Transom trim gauges does not report properly
Service provider has verified that Temp, Oil pressure and RPM are reporting from the engine. All gauges move from low to high and back to resting position when engine is started. Service technician indicates it is likely the Analogue SMartcraft Gauge interface. I have a mode AGI 8M0033330. Are other modules compatible? If not any one know were i can find a Smart Craft AGI 8M0033330?
Second Part:
1.5 years ago purchased Vessel View Mobile. Figure I would be clever and just connect it up to receive readouts on my tablet. I located the 10 pin connector and the line that indicates the termination point. How would vessel view mobile mobile connect based on picture?
Any assist is appreciated.
"Go Griffs"
Post edited by Griffs_Aboard on
Can you pull the dash gauge panel off and post some pics? Looks like there are a couple options for the analog converter. And surprisingly cheap (for a Merc part):
https://www.partsvu.com/agi-analog-convrs-8m0109742.html - with PCM09 ECU
https://www.partsvu.com/analog-conv-agi-892486k08.html - non PCM09 ECU
I don't think you could run VVM and the Smartcraft gauges at the same time unless you add a J-Box.
On the jbox for vessel view mobile I should be able to mount pic below beneath dash and use the 10 pin connector.
appreciate the responses.
