Vacuflush Water Valve Replacement
YYZRCYYZRC Member Posts: 5,586 ✭✭✭✭✭
Anyone done this?  Mine has sprung a leak.  Looks like an easy re-and-re based on the pic of the part but figured I'd ask.
    Yes, fairly simple to change.  Just make sure the part behind it, that has a spring to pull the pedal and ball back into place, is snug when putting back together.  Those two screws, which are long, need to be tight, but not too tight.  You'll know if your pedal & ball don't swing back correctly.
    Thanks @Dream_Inn - will give it a shot on Friday.
    edited August 2022
    Done and great tip on the tightness of the bolts @Dream_Inn - I had them too tight initially and it wasn’t springing back closed.
