Replacing spin latches on windscreen window/door (solved)
echandler1971echandler1971 Member Posts: 244 ✭✭✭
It finally happened, the wind blew my windscreen door shut, destroying the remaining plastic spin latch. I found the same latches on Amazon, but I’m wondering how I deal with the rivets that these old latches were attached to and how to go about attaching these new ones. Do I need to buy a pop rivet gun or can I use a screw?
Dan of Steel
'05 Rinker 360 Fiesta Vee
  • YYZRCYYZRC Member Posts: 5,509 ✭✭✭✭✭
    I drilled them out and used screws on my former boat.
    They are stainless and so will be a tough drill but can be done carefully, don’t slip! I got my replacements from TaylorMade and they provided the SS rivets.
    I would remove that side of the frame from the glass. It’s just held in with two Phillips screws.
    I also don’t understand why they used SS rivets on an aluminum frame.
    SS rivets require a special rivet tool as well.
  • echandler1971echandler1971 Member Posts: 244 ✭✭✭
    edited July 2022
    I'm kinda worried I would mess up the glazing if I pull off that section. I think I'll angle grind off the rivet nubs, drill them out, tap, and use screws as you said. One of the latches has been broken since before I owned the boat, so it was definitely time to do something. Also, the weather stripping on the door is nearly disintegrating, so may as well do an overhaul.
    I ordered the latches today and they arrive tomorrow - Amazon is great.
    Dan of Steel
    edited July 2022
    I used a regular rivet gun without issue, as long as its not a cheapie that will break before the pin does.
    Ok, I got a Widowmaker 2000 rivet gun from Harbor Freight and ordered some 3/16 x 1/2" barrel rivets on Amazon. I also got 3/16 x 5/8 and 3/16 x 3/4 just to cover all bases. I'll post pics when I'm done.
    Dan of Steel
    1. Grind off top of rivet
    2. Hammer rest of it into window - carefully
    3. Drill out with 3/16” bit
    4. Use (in this case) 3/16” x 5/8” rivet
    Windshield Double Latch Nylon https://a.co/d/eNedQ66
    its on there tight. Did both of them.
    Dan of Steel
    I also redid the weather stripping and cleaned up the metal.
    Dan of Steel
    Nice job!  Did you go stainless or aluminum rivets?
    Aluminum, only because the window frame is. I have plenty more rivets if they corrode out.
    Dan of Steel
