320 FV Location of A/C sea strainer
All is working well but I’d like to check and clean the sea strainer for the A/C.
where is it located on a 320 Fv?
  • Dream_InnDream_Inn Member, Moderator Posts: 7,959 mod
    It should be in the middle under your mid-cabin cushion bed area.
  • AtlanticJimAtlanticJim Member Posts: 27 ✭
    Like … under the dinette area?
    No, under the sleeping area in the back of the cabin.  You have to lift up the cushions and there is a panel that you also lift up.
    Ah ok, thanks!
    The good and the bad. Got my gennie running again with a new impeller and sea strainer basket (imagine my surprise to see that there wasn’t one in there at all when I first opened it).
     On to the AC sea strainer … ugh must be two inches of old water, black but not black-water in that space where the sea strainer is.  Not a job for today,  covered it and walked away. Where does that water drain?
    There is a mid bilge under the bed where it will sit. If it’s nasty you will want to vacuum or sponge it out
