Emergency workaround for broken gear lube fitting
LaRea
Member, Moderator Posts: 8,082 mod
With a Bravo 3 outdrive, the gear lube reservoir has a hose to a plastic fitting on the transom. My fitting broke this weekend, draining the gear lube into the bilge and disabling the engine. My mechanic came up with an emergency workaround so good that I thought I'd share.
In this diagram, the fitting that broke is #6. We were on Day 1 of our only boat trip this year, and I thought the boat would be disabled until we could get the part. His solution:
1) remove the broken 90-degree fitting #6
2) relocate the reservoir #1 behind the trim pump, secured with zip ties
3) Connect fitting #8 directly to the transom assembly
It took him 30 minutes and we were safely back on the water.
I couldn't sleep very well that night.
