Halon System
YYZRCYYZRC Member Posts: 5,586 ✭✭✭✭✭
I removed my halon system over the weekend to pull the fresh water tank out so that I could add a drain to the shelf where the fresh water/poop/hot water tanks live.
This caused me to read into halon systems a bit.  They're no longer offered due to the impact to the ozone layer but are still used in airplanes as there's no equally efficient/effective alternative.  For boats, you are not required to proactively remove your halon system so long as it is serviceable.  The halon gas is no longer produced so recharging a halon system is done with recycled halon.
Some interesting discussion here:
https://www.cruisersforum.com/forums/f117/question-about-removing-halon-extinguisher-207608.html
When going down this rabbit hole, I also learned that 52% of boat fires originate with the batteries/electrical system:
https://www.boatingmag.com/fixed-marine-fire-extinguishing-systems-for-boats/
My halon tank is fully charged and in great shape (no corrosion), so I will reinstall it, but I am going to relocate it to the port side of the boat near the batteries/charger/etc.  As a bonus, this will help mitigate my starboard list.
