Generator
Hi,
I have a generator on my rinker 340ec.
it was running fine all season, just this past week I went it fire it up and it ran for about 5 seconds and then quit. I opened the engine hatch and realized there is a reservoir that is empty. Would this be what is causing the problem? If so what is the reservoir for? Coolant? Oil? It’s a clear bottle?
thanks for your help!
    That’s the coolant reservoir.
  • rmrstlmormrstlmo Member Posts: 238 ✭✭✭
    It will shut down if it gets too hot.  Refill with coolant and watch for a leak.
    Ray
    2006 390
    Previous 2000 340
  • brettwilliambrettwilliam Member Posts: 15 ✭
    Thanks, any particular coolant?
    I use the orange one that says it works in all makes.
    Bigger trick is getting any trapped air out of the system.
    Assuming this is a Kohler 5e?
    The coolant reservoir being empty is not ideal, but how full is your heat exchanger? Was it full to the top or low also? Agree with Dream I use the Prestone any color coolant.
