Faria Gauges
mvnmvn Member, Moderator Posts: 763 mod
Probably one of the top 10 topics on most boating forums......
Countless complaints about tachometers and sticking needles, inaccurate readings, etc.  The common answer is always to send the tach back to Faria for repair as they are warrantied for life.  In my case, the tach was off by 1,000 rpm at WOT of 5,800 rpm so it was reading close to 7,000 rpm.  No amount of "tapping" helped.
When looking at potentially getting a new one from Great Lakes Skipper, I closely looked at the photo of the rear of the tach.  Low and behold, I saw a small hole near the outer edge which is usually covered up by the rear retainer bracket. The hole gives access to a trim pot!  I verified mine had a hole and pot as well.  Setting the idle speed to 2,000 rpm with the Rinda Techmate, I adjusted the trim pot with a Torx T6 bit.  Once the reading agreed with the scan tool, all was good!  5,800 rpm WOT right on spec.
No need to return to Faria or put up with bad readings.  I have never run across the mention of a fine adjustment on the back.  A deep dive into some online manuals does briefly mention it if you know what you're looking for.
Mark
2019 MTX20 Extreme
    Where did you hear “warrantied for life”? All other commentary here has been that you can pay to get rebuilt.
    edited September 2022
    True, but I see both comments on this site.  You are right, they have a repair pricelist.
    In any case, here is the final word......
    https://fariabeede.com/2-pages/warranty.php
    Maybe there's confusion with respect to their standard repair pricelist and replacement if not repairable.
    Bottom line.... I'm happy that everything is working now!
    Mark
    2019 MTX20 Extreme
  • goalie59goalie59 Member Posts: 356 ✭✭✭
    I fell into the Faria trap with my 320. After replacing them they only worked well for one season. I ended up linking smart craft to my raymarine through a gateway. Digital is the only way to go in my opinion.
    With VVM I rely less on the gauges but look at times as a backup reference - should the VVM/BT crap out. The only one I want fixed is the LCD display for the in hull depth sounder, flickers digits.
    The in hull depth sounder is about the only original gauge I look at now with the VVM.
  • YYZRCYYZRC Member Posts: 5,509 ✭✭✭✭✭
    I wonder what the Volvo Easy Connect app is like?
  • rmfridayrmfriday Member Posts: 106 ✭✭
    i used fox marine gateway to get digital info from the engines to my garmin 942
    way better then the Faria gauges...
