260 EC (2014) Water intrusion near kitchenette.
I have sealed every screw and possible opening on the exterior but water seems to always end up at the base of the kitchen. Anyone experience this or have suggestions?
    Have you resealed the rub rails?
  • aero3113aero3113 Member Posts: 9,982 ✭✭✭✭✭
    All the screws under the windshield seal?
  • drbeepdrbeep Member Posts: 34 ✭
    Yes.
    I missed those. I'll try this.
    Check the sealant between the stainless beauty ring and the white plastic on the port light windows. If it has separated, reseal with 3m4000uv or life caulk. That is where I was getting water from. It's usually the window in the aft cabin since it is the most vertical on the boat.
