Actually generator
rasbury
Member Posts: 9,027 ✭✭✭✭✭
I have the Kohler 5e generator..really have not had much problem with it but lack of use may have caught up to me...so on a recent outing, fired it up but did not seem to be moving water so I shut it down assuming either the impeller went or the coupler, which I had to replace shortly after we bought the boat several years ago....I pulled the pump off and the impeller looks intact. I don't see that orange coupler behind the pump? There is another cover behind the pump, behind that? I did bump the starter and the shaft is turning which if the coupler is toasted the shaft would not turn correct?
