Trim up sender
rasbury
Member Posts: 9,027 ✭✭✭✭✭
After getting my trim pump functioning properly now moving on the the trim indicator and the limit switch. I had recently installed both this and the limit sender as the transom was apart. I think the trim sender was working for a bit but stopped...anyway, found this really good section of what appears to me a mercury chapter dedicated to the whole trim system...probably can't post...anyway, gives me an ohms test through the disconnected leads in the bay..which it fails. New sender, not smiling.. It mentioned one other test I had not done and by myself would be hard- disconect the puck and try the test again. If the reading now reads fine, grease the hinge pin in bell housing...could not do that so I marked it down and then raised it- the pin is traveling with the out drive and not turning the trim sender! That is 145 ft pounds, how can the OD break it loose and turn it? Ordering the tool...don't get that one..u
If this is your issue you may want to look at sending yours out to www.jrmarine.com here in Ohio. They do a rebuild for $275 as opposed to a replacement at about $1k from Mercury
