Waste tank sanitation?
MiamiAG
Member Posts: 210 ✭✭
So going for my first pump out this weekend... Once I pump out the black water, what do you do to sanitize the waste tank? I'm trying to kill the smell that comes out every time someone uses the head.
Also wondering what do you do if you need to pump out your head and you're not inland. I'm planning a trip to Bimini/Bahamas.
Thanks,
A
Thanks,
A
There are lots of holding tank chemicals people use, mostly personal preference and success, you really don't want to sanitize it asn you want the solids to break down. As for the odor when using the head, you need to add a Big Orange filter or similar..they 100% solve that problem.
http://bigorangefilter.com/
Do you have a Y valve on your waste system?
A Big Orange filter is a great charcoal tank vent filter as others have said, you can also DIY for about $10 and an hour of your time. Works the same and stops the stink from the vent very effectively, it's also easily replenished each season. Charcoal pelletts in a 1-1/4" pvc pipe with hose fittings on each end works like a charm.
At the pump out make sure the tank's emptied well and then flushed and emptied again with about 5-8gals of water from the dock water supply. Also make sure to put a healthy dose of new RV waste tank treatment in the tank each time it's emptied.
As a last resort it's legal to empty the treated tank effluent off-shore more than 3miles if you have a macerator and Y-valve.
Here's a couple pics of my simple tank vent carbon filter. Good luck, Mike
The basic aquarium pelletts and pvc pipe with hose fittings and a bit of course foam to contain the pellets inside. I put a set screw in the caps so I can get it apart each season for fresh carbon pellets
Then just take a razor knife and cut out a section of the vent line to install your magical de-stinker at a slight angle with two hose clamps. Easy, easy $10 project and the Admiral, your guests and dock neighbors will thank you.
