Raw water pump
rasbury
Member Posts: 9,027 ✭✭✭✭✭
Well...have been working on some things and in the process replaced the impeller that desentagrated...got it all back together and the pump does not seem to be pulling water and I don't understand why. Now I have a thru hull water pick up as well as a foot pick up that goes into a strainer and then the pump. I opened up the strainer and there is water in it, not full but up over the inlet to the pump. Over the years it seems I have had issue running this set up on muffs and generally avoid it. I pulled the end caps off the heat exchanger and don't see anything in there. I have what would seem to be the hard round edges of the old impeller and would assume the smaller pieces would make it through the system...
The only thing I can think I'd I'm pulling air somewhere. How much of an air leak would cause it not to draw? Like the thru hull...I have it closed but maybe it's not sealing? The strainer seal?If I take it to the ramp and just let it run, if there is no water in the system would it read on the temp gage or where is that sensor at? I suppose it is reading coolant...any way the system can get locked and just won't pump?
I think your boat needs a good run on plane!
The local county waste management will accept 20 gallons at a time from my county residence for free. Guess they don't want us dumping in the back yard...and it's right around the corner-
