Anode kit
My quicksilver Anode kit for a Gen 2 Alpha 1 came with a small rubber plug ? Not sure where it’s suppose to go ?
    edited May 2023
    It goes in the hole on the top side where you screw in the round anode under the cavitation plate.
    I never had these but finally bought a pair and put on after anode change. Should keep those little oyster things out clogging up the hex.
  • Rinkerfor4Rinkerfor4 Member Posts: 12 ✭
    Nope I got that one.  It’s different. I’ll
    post a pick of it
    I have no clue what this guy is for
    That looks a bit more serious! It came with the kit? I has an alpha ll drive years ago....don't recall it unfortunately...
    Yes it was in the bag with all the bolts
    I’ve never seen that one….
    Well mystery solved.  After some googling and figuring out the Mercruiser Parts site.  It’s a seal that goes up into the Hydraulic line block.  Up under the gasket and anode that bolts to the line block on the Transom housing
