Run on or dieseling
lmaylenlmaylen Member Posts: 5 ✭
Thanks guys i put in factory recom. plugs. Adjusted idle mixture screw opened 1/4 turn. Helped some. Then as someone suggested found out idle was not getting all the way back all the time so I adjusted the linkage 4 rounds now goes back to idle stop each time idles aprox. 650 rpm at neutral even after 3 mile wot. With about 15 second idle time Did this about 12 times. Had small run on 1 time about 3 kicks. The rest no problems. About 95 degree outside. Temp. Thanks guys for the info. Larry
