Engine Coolant Loop Leaking at Water Heater
YYZRC
Member Posts: 5,491 ✭✭✭✭✭
I've now eliminated all sources of water in the bilge except the water heater. I am tired of the small leak at the fittings where the "coolant" water from the engine circulates through the water heater. I've tried double clamping with new clamps and cutting the hoses shorter, to no avail.
Any suggestions?
Any suggestions?
EDIT: discovered that fresh water is leaking out around the fitting where the coolant loop barb exits the tank.
