2005 342 FV Cool Fuel Module leaking water
Maddux99
Posts: 22 ✭
Hello everyone, when I opened up the boat last week I had a leak on the port engine cool fuel module. The leak is due to a broken plastic fitting on the lower water hose. I have already purchased a new hose bib assembly as I could not get a new plastic fitting separately. My question is, can I cut the hoses and use barb fittings to couple the new hose ends with the new bracket and fittings to the old hoses. That way I won't have to dig in so deep to get to the orifice metering assembly.
2005 342 FV
@Maddux99 since you have the assembly already, I would install that… To do the repair I did, the whole module will need to come out to do it correctly.
Grahamu, the water heater is beside the starboard engine.
MH342, I had not thought about the speedo tube, but that wasn't it. Besides, it leaked anytime the engine was running , boat didn't have to be moving.
There is an aftermarket heater installed in the dead space behind the fridge. I knew it was there but I thought it was electric only. The water hoses were hidden inside a corrugated pipe wrap until I got the fridge removed and crawled in there where I could investigate. They were also hidden very well in the engine bay and I didnt notice they went somewhere other than just to the water heater. As it turns out, the line comes out of the engine and goes to the space heater, then goes to the water heater, then returns to the engine.
Water pours out of the space heater when the starboard engine is in service. For now I'm going to bypass the space heater. I plan to replace it before winter, but it's not a high priority for us since we don't boat much (if any at all) in the cold.
