Power Steering Actuator Leak
mvnmvn Member, Moderator Posts: 763 mod
Asking for a friend.......
I traced an oil leak in a friend's 5.7L mercruiser powered boat to a leaking power steering actuator cylinder.  Other than replacing the entire actuator with a new one (original one no longer available but superceeded ones are), are seal kits or a rebuild service available?
Mark
2019 MTX20 Extreme
  • PickleRickPickleRick Member Posts: 4,407 ✭✭✭✭✭
    You can get seal kits.  If you use your serial number you should be able to search for the correct part number for a repair kit.
    If it's like the trim arms it's easy.  Just messy.
